Old 06-15-15, 06:59 AM   #9
Brandon727
Originally Posted by iamgeo View Post
I imagine you could remove the spout and place a washer with a small hole in it to restrict the flow. If you do this every week by changing the washer out to one with a smaller hole, the flow will get slower and slower. She will not be the wiser.
I like the way you think.
I went ahead and ordered a flow restrictor from amazon for $12 http://www.amazon.com/gp/product/B00...ilpage_o00_s00
I'm currently adding spray foam to the underside of the tub to keep the water warmer longer(might offset the longer fill time), the tub will be installed some time next week. Will update with progress
Brandon727 is offline   Reply With Quote
