Old 01-21-18, 11:41 AM   #1933
Originally Posted by Rebuilder View Post
OMG! What an epic thread!
Thank you so much AC for your unbelievable commitment to this thread. I've never seen anything like that in any other forum.
I'm so eager to start my home made heatpump projects. I have tons(pun intended) of donor projects to choose from(a bit of a hoarder). First I think I'll try getting some heat going in my tool shed and barn after I do some "insulate, insulate, insulate".
Rebuilder,
It takes a dedicated person to read through the thread. Congratulations!
You are correct to minimize heat loss (minimize infiltration & maximize insulation). When you feel that you have done what you can do, then take a look at what would be required to heat your structure(s). At that point, your heat loss will be smaller, so your heat pump that will do the heating will be smaller and easier and cheaper to build.
Good luck, keep us posted, and remember, we love photographs of projects.
Best,
Rebuilder (01-21-18)
