Old 06-12-18, 04:20 PM   #6
CrankyDoug
Originally Posted by Elcam84 View Post
Gotcha. Have seen a few of those in Misissippi where my relatives have land they grow trees on.
Funny coincidence... I just got done pulling the pipe out of our well. 100' of pipe and a jet at the bottom. I thought the foot valve was leaking but it turned out to be the supposed stainless nipple rusted out over 6 years...
Before pulling it out I blew as much water out with the air hose that I could. Then after pulling about 40' out and taking a break I blew it out again. This time I blew a hole in the fitting and it was much lighter as the water was gushing out as I pulled it out.
Headed to pick up a piece of pipe to extend the well casing and drop in a submersible pump. Not playing with inefficient, noisy and maintenance hog jet pumps anymore.
Oh and my water has allot of rust in it from the casing and there is some from the iron oxide in the soil. However the iron oxide is in sand instead of clay here. Looking at local drill records we have sand down to around 150'. Once I run the pump for a while every spring it clears up and it's crystal clear unless I don't pump water for a few months or so. Looking forward to watering the trees and grass again...
I am on my third foot valve in 20 years. The only part that is stainless is the screen. The body is cast iron. The first one blew a hole in the side, as much from silt abrasion as from rust. The second one was less than three years old but looked terrible. The pump installer refused to use it.
I considered a submersible. But they are more expensive than a jet pump and my wife won't bother to turn off the pump when she runs it dry. The permanent solution is going to be a timer on the well pump.
If time permits I am going to pick up two IBC's and use them as a buffer between the well pump and a separate house pump. The house pump will be below the IBC's. I can put a level switch in one to shut the house pump off automatically if the tanks get too low.
The well is fine - the problem is a "loose nut" at the garden hose.
