Old 02-19-13, 05:11 PM   #11
The rubber seals on the heating elements in my 74 gallon tank started leaking first.
Then the large seal holding the HX coil joiner plates (for cleaning out the HX).
I guess the rubber wasn't rated to last under higher temps, it dried up and got brittle.
I've been thinking about a hot-air collector panel for my cold basement problem.
Saw some on Ebay for $1,000+ !!
If I try hot air, It's going to be a full DIY job..
