I repurpose the SSQA plate one more time. I added a hitch for moving and parking trailers. I still need to get some paint on it.
I used scrap yard steel and I already had the hitch so this cost me $6 to make.
The bottom back angle is 6" x 4" 3/8" angle. It was three pieces that I welded together.
Solar Install 12.5 Kwh- To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
Mini Split installs - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
EV Chevy Volt - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
