I have seen this one (sorry in French, but there is some graphs) :
Enregistreur USB longue durée température et humidité - T°, %RH et point de rosée pour Diagnostic de Performance Energétique (DPE) ou autre - 64.50EUR- achats éconologiques
It saves up to 16000 points with temperature and humidity. You configure the time between the records from 2s to 24h.
Velleman sells in US but I don't know if this recorder is sold in US.
Denis.
Earth absorbs 1.8 t CO2/head/yr, while a French generates 6.2 t CO2/yr To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.- kg saved 06/08-08/09: 1816.9+382.9 (ecodriving / 1420mi not driven) = 2199.8
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. (2.66 kg/l diesel)
- kg saved by 3kWc photo-voltaic solar panels : 187 kg/yr
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. (59.1 g/kWh)
Radioactive wastes saved by 3kWc photo-voltaic solar panels : - Long life (>100,000 years) : 2.85 g/yr (0.9 mg/kWh)
- Short life (<300 years) : 31.7 g/yr (10.0 mg/kWh)
