Is anyone up for a discusion on the pros-cons flat plate HX vs copper
Aqua Systems efficient Liquid to Refrigerant Heat Exchangers HX both are about the same money but maybe the copper wins over the stainless??
One other detail I had seen was the reverse valve in a GSHP caused a parallel flow condition through the HX reducing the efficiency as opposed to the counter-flow.
Thanks Randen
