Do not buy this brand. They are a pain. I called company they are not much help.
I will be removing the water saver drain valve kit at some point.
I have one HydroRight Dual Flush and they real deal. If they would make one for the 3” flush valve toilet I would get them.
Solar Install 12.5 Kwh- To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
Mini Split installs - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
EV Chevy Volt - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
