I picked up two packs of 2 Luminous EXTLED at costco yesterday. $22.99 a pack. Specs are 470 lumens 58 lumens/watt 8 watt 25000 life, 3000K
The reason I grabbed all 4 was I needed 3 in my dining room chandelier and 1 in my basement. Dimmers were in use in both places and I didn't see the point of saving a couple of bucks to get dimmable CFL's which were about $8 each last time I managed to find them.
Last night I replaced the downstairs one which had just been a regular 13W CFL and I had to run the dimmer on full. The light coming from the bulb is much whiter then the CFL it replaced and really makes the one remaining dimmable cfl on the circuit look quite yellow. I prefer the new light.
This morning I did the dinning room chandelier. The 3 bulbs replaced three candelabra 60 watt bulbs. First thing is the bulbs are way brighter then the 3 replaced. Light is a bit whiter. There is however an issue. The dimmer appears to be a special one to allow dimming of CFL's. I seem to remember reading that on the box. Anyway At full power it makes the LED's flicker. At lower power they flicker then go live.
Right now I'm thinking I'll switch the dimmer with the basement dimmer. Then I can take that bulb in the basement and put it in the last remaining spot with IC beside the bed. I can then use the fancy switch with CFL's in the basement where it doesn't matter.
Overall I like the lights but think they're still pretty pricey. I'm however not impressed that they don't handle the funky switch.
