Old 08-02-10, 08:29 AM   #42
bsmith
Cheap DIY'r
Its got 10A output relays that should work for that applications. I would keep the pump below 4-5A for AC version and would probably advise to put a MOV in parallel with the relay contacts. You always connect an external contactor to the unit if you wanted something beefier.
bsmith is offline   Reply With Quote
