What cell phone provider do you use? If it is ATT or one that uses a sim card you could get a mobile access point that could be setup to let them in to fix it.
I have two of the here.
If my internet goes down I just take my sim card out of my cell phone insert it into my USB hot spot that connects to my router everything here is back online like nothing happened.
We do have to be careful to not use too much data but it is usually only out for a couple hours.
Solar Install 12.5 Kwh- To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
Mini Split installs - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
EV Chevy Volt - To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
