It's not clear how you are current-limiting the power to your LED light(s).
I'm assuming these are automotive 12v strips that are usually used for under-dash effects and probably just have a resistor in series with the LED strip to make the current appropriate for the standard 13-14ish volts that cars run off of. Most of the ebay auctions in that price range with the description he gave are advertising these for automotive use. Curious what a kill-a-watt says for their usage since a post I was looking at said light output wattage as opposed to the actual input wattage. If it isn't PWM it could be burning a fair bit through the resistor.
