Thank you for the input. It is great to get the positive feedback. sounds like I will be putting in 2,000 lin ft.
Is it better to stay with 250 ft loops?
I was thinking that perhaps a good way to circulate the water is using an RV water pump for each room, (3 pumps) each on its own thermostat, less than $100 per room and inexpensive to swap if/when they fail, they are very long lived and can handle reasonably hot water.
