Old 12-26-18, 07:23 AM   #8
Mikesolar
Mikesolar's Avatar
Originally Posted by Mukiwa View Post
When we were getting quotes to get mini splits instaled they wanted like $15k for 3 heads so we tossed that idea. Then I watched a video and realized how easy it is so they are back on the table.
$15k? Wow, I don't charge enough.I don't believe you will not find a multi head unit that does not require a vac pump and nitrogen, gauges etc to install. There are some single head ones but you cannot cut the tubing if they are too long as they are under a vacuum. I'm not fond of them anyway because you cannot guarantee how good of a vacuum is in it or if there is enough refrigerant in the system. I have had to add more to some that were purchased by a homeowner and I was asked to install.
