Originally Posted by Elcam84
Yeah it's a pretty common issue here. It's up to just over 90* now... Short run to the main as well. The main is only a 2" pipe and dates back from 1960 or so.
As for burying it deeper... My 100' well has a water temp of 70* which is right at the correct temp for water at that depth here. So I'd have to dig really deep.
It's really annoying to not have any cold or cool water supply. You don't realize how important it is to have cold water until you don't have it. Fortunately I end up using only cold water at the end of a shower and it's not cold enough to cool off before getting out of the shower.
Your answer is right there in
bold.
But, no digging required…
Install a
“U” shaped pipe inside your well casing along side your existing supply line from your pump and connect it to the city water line.
The
“U” shaped pipe will act as a heat sink for the city water.
Just remember that you will need to size the pipe accordingly. 200’ of 3/4” pipe would probably have reduced flow. 1” dia. pipe should be about perfect. Then fully insulate the pipe running from the well to the house.
Do it and report back…😉
