The MTM tracker uses relays. If the motor current is high (mine was only a couple of amps at 12V),
the relays will slowly wear out.
It might take a long time with light power loading or, the relays might fail in one summer.
The RedRock tracker will last longer, since it uses transistors, instead of relays.
