Originally Posted by Acuario
Not sure I'd be too keen using a plate hx. I did think about it at the beginning but discarded the idea due to the pressures involved. The other thing to bear in mind is the velocity the gas travelles through the system - I've no idea what that is mind, but reading anything written re refrigerants and they frown upon anything that impedes refrigerant flow.
Nigel,
I think you are right to be cautious about pressures in a Brazed Plate HX. Pressure information is readily available from selection literature on the manufacturer's web site.
But I don't think that Brazed Plate HXs would be a problem, regarding friction losses... they're pretty well designed.
The main impediment I see is cost... I've been able to locate some pretty good deals on ebay.
