Old 02-09-15, 11:33 AM   #10
Greg
Default Waste oil heater
Here is the heater in my kennel it purs along quite well un attended for days at a time but due to the fact I burning 50% WVO I need to clean it every few days. You can see the hydronic flow control in stead of carburator. I also hav a selonoid valve for a two speed circuit could be run off a thermostat. The blue valve is a electric valve to be used as over temp safety or under temp. I cut up a barrel for the bottom pan and it runs outside 3/4 in pipe as overflow drain. This little rig works great it heats 600 squar ft 9 ft ceiling in some cold northern alberta temps. I have in floor heat tubes and hope to place gas hot water tank over the top using the stove chiminy as the heat source for the tank.
Greg
Greg is offline   Reply With Quote
