A/C what happened to thread progress?
I have a MPX2010DP differential pressure "AIR" sensor that I got for my DIY HRV.
Idea was to keep house pressure a little above outdoor pressure for Radon mitagation.
Problem is that I don't know how to protect outside hose end from wind effects.
EDIT: Possibly take a sample every second for a minute & average them.
I think that the liquid pressure sensor that I referenced in post #232 would work reliably long term, I hope. I am ordering one for loop input pump.
On my current boiler system, I have 2 Taco water pumps in series with a on/off switch to each.
There is a manual read pressure gauge on pumps output.
It is very easy to check that each pump raises output pressure by about 3psi, both on about 6psi.
If a valve is closed in output pipe the pressure doubles, thus it is easy to determine if the pump is working and flow is happening, with a gauge.
Arduino code would be easy.
Note: 1psi = 2.35' of head.
