Mab
I used the kit from Hübner however the IGBT drive circuit did not perform well and took out some IGBTs so we made our own drives. The processor is very well done but I don’t know if Johannes has improved the drivers but you should check with him
My abilities in electronics is novice and I needed a lot of help from a person with more advanced skills
Even though we made a lot of smoke and shoveled a lot of silicon at the project
If you lack the talent I would caution the attempt
Did the Hughes not use two of those motors for their S10???
The S10 that I have is the OEM production of GM with an 85 kw motor and a lot of other trick things that one would need
Randen
