Originally Posted by Xringer
Just to be clear, that 143F isn't the setpoint we are using.
That's how hot the Tee connection got during a run cycle.
(The Tee is where the HX loop enters the tank).
However, on the 16th, we turned up the setpoint to 130F. It was at 120F.
My wife really likes the 130F setting for hand washing dishes.
I'm thinking of moving it down to 120 or 125 during the cold months.. For efficiency.
Based upon your reports, apparently the A7 is capable of supplying normal residential DHW requirements.
However, in the winter cold season my DHWH, thru a HX, also supplies my in floor radiant system, a substantially greater demand. During this short cold period my thought is to use the propane fired DHWH as a low set point pre heater and the A7 as the secondary top off heater. Relative set points to be determined.
