If this is an inverter mini-split, if you figured this out and actually did it, you'll be giving away the ability for the system to ramp up and down depending on the load imposed on the unit, which the compressor would probably end up running at a fixed speed(max speed?), you'll be giving up a bunch of efficiency related to its normal operation at lower output rates.
