that looks like it might be pretty much proportional. A 1/7 reduction of depth results in a 2/15 reduction in R value. If you assume there was some rounding in the data that you found it may be even closer. If you make the same assumption about the 8" insulation(that its r-value is proportional to it thickness) then the 8" @R-25 compressed to 75% of its thickness should end up at about R-18.75 which is what fornax speculated earlier.
