AC, actually I hope you're right about the stuff. And I did miss the extreme cost of it. But I'm not sure they aren't using the extreme price to lure in people with the reverse psychology of "it must be special to cost that much." Time will sort this out if it's the real deal. But part of my harsh reaction came from your implication, whether I misinterpreted it or not, that I was not a supporter of radiant barriers. That is clearly not the case. But I do believe in targeted application of it and the use of clear principles of cost vs benefit analysis in its use. Insulation is still required in houses over and above use of radiant barriers.
