Originally Posted by Alister91
I'm just wondering if you guys have found any good LED bulbs. Having recently read up on them and shopped around it looks like ATM they are #1 very expensive and #2 can't put out as much light as a CFL.
LED lighting expensive, but if you get them straight from China via ebay, they're more reasonable. I did that, and although the infant mortality rate was fairly high (15% within a month), it was still cheaper and the variety of lighting was far greater than where I live (USA). Trying to return bad bulbs to China is a losing game.
Yes, you are right, the total light output of LEDs is lower than CFL, but the light is usually focused by built-in plastic lenses, so the level of useful light is quite acceptable.
In my opinion, the best bet is to use compact fluorescent for indirect and fill lighting, and LEDs for task lighting. That way you are turning the best attribute of each type of light to your benefit.
Best,
