What you are saying about the voltage needed to charge a 48 Volt battery bank is certainly true. That is why I was confused by the quote in the TS-60 manual, "Do not connect a solar input greater than a nominal 48V array for battery charging." Not sure what that means.
I am sure I will have more questions as I put my system together. Thanks for the recommendation on the Northern Arizona forum.
