I've wanted to do this for a while, but with my solar hot water panel setup I didn't see a need. My plan was to run ~300' of 1" pex (grade A, it has a higher pressure/temperature rating) to get a couple gallons of capacity (~9 I think). Drain it and bypass it for winter. I wouldn't use CPVC.
I am excited to see someone try it!
