The bars aren't constant. I only see mine sometimes. I'm also using less then 1 kwh/hour for the last few months so maybe they have to do with consumption. I'll see if I can get a picture when I read the meter today in a few hours.
If you check the supported meters link here
http://www.bluelineinnovations.com/i...d%20Meters.pdf
you'll see a C2S which is what I have. part way down. It has a picture of the bars. Just checking mine I only have a small arrow point to the right at the moment.
you should put together a spreadsheet of your usage then start a thread similar to mine and doax's
http://ecorenovator.org/forum/conser...-tracking.html
put up some details about your house and we can see if anything jumps out. I love looking at those things.
