Dryer efficiency: high or low heat?
I have a gas dryer, and I was thinking about the most efficient way to run it. I would assume that using a lower heat setting would be more efficient. It will take longer to dry, but the heat would be used more efficiently (less losses). At least thats what I would think.
Thoughts?
