Old 05-22-11, 07:49 PM   #17
S-F
You Ain't Me
S-F's Avatar
There is no difference is the total amount of vertical distance the water has to travel. It makes absolutely no difference as far as load on the pump is concerned. The only thing you have to loose with more shallow wells is efficiency of the loop, as I mentioned earlier.
