Let's just say there was an incident while I was trying to get out the old fan motor, and now my air conditioner needs to be charged.
I've always wanted to try and recharge an air conditioner with propane. Is there a how to out there anywhere for this? Everything I google is about a car. I can figure out the plumbing, but I'm not sure what I need for gauges. Can I just use a pressure gauge with the right range for the high and low side, or do I need a fancy refrigeration manifold set?
Now that I broke the seal I'm going to get a little more custom and try to make a real heat pump with reversing valves.
