Originally Posted by SimpleManLance
I just checked out both your systems. very cool! On your drain back system, don't you need some sort of a vacuum break to get the water to drain back into the 6 gallon tank?
I forgot to mention that I went up on the roof and installed a vacum break type valve at the highest point where hot water leaves collectors on route back to drain back tank. This valve allows a pinch of air into piping as water flows by but will not allow water to leak out. Just perfect for the application.
Pat from Warwick, RI
Please Note:
Comments and/or suggestions I make here at the forums on 'your' projects as well as my own have all been carefully and scientifically calculated by 'the seat of my pants' To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
