I don't know why myself but it is a good question. It's for use on walls.
Is there a particular reason why you are not blowing behind netting? It's clear as day that when you blow behind netting you do a better job because you can kick the tires, so to speak. When blowing behind a wall of some kind you don't know where the soft spots are and you couldn't do anything about them even if you knew where they were.
My project:
