Originally Posted by Xringer
I'm not sure, but I think the power problem is a bug in the control program.
Not with the plumbing.
I eagerly wait to see.
There has to be some concise formula to follow for the charge. Where is it? I can't help but suspect that the power issues you have seen are due to an incorrect charge since everything else you have done on the other unit seems to have gone above and beyond. If you think it is indeed an FW problem have you contacted Sanyo about it? I'm sure they have more than a few of these in the field and should have more than one report of this.
