Originally Posted by MEMPHIS91
I don't really think so. In order to properly insulate the containers you either loose most your inside space or you have to spend a lot of money cutting and welding to make them usable. Plus now the price is going up more and more on them. Maybe good idea if you live in FL and want to paint in silver to reflect tons of light/heat. But you still need insulation.
I think it depends on the construction techniques used. Someone could set up a frame/insulation on the exterior instead of the interior. And if they did insulate the interior, the outside would make the perfect base for a solar thermal hot water system. I guess like most things, it depends on what you do with it.
