Have you tried coasting in neutral in the Leaf? You can hold the "shifter" in N for 2s or above 7MPH, just shift into R and it will beep and go into neutral.
Does it still have the stock Bridgestone Ecopia EP422 tires? If so, pump them up to 42-45PSI and coast with the best of them! They are very low rolling resistance tires.
Congrats on the EV. We are thoroughly enjoying our two EV's (Leaf S and e-Golf).
