I got the concrete slab poured for the downstairs floor.
1440 ft2 full floating with 6” of type 2 EPS under it and 7” around entire perimeter.
Old sub-contractor used young labor & did a nice smooth job, he said that the rich mud was easier to finish. I got it done about a month before Winter set in.
About 5" thick on average, high strength 5,000 PSI & double fiberglass
(which are now smaller strands than they used when i last did this)
Ran a 1/2" rebar (#4) all around perimiter about 5" in from edge.
The heavy gauge 6" x 6" remesh in the slab was handy for attaching the pex with zip ties.
I tried to run the 1/2" pex at 6" on center but with all the sweeping turns it averaged 7”
I reduced the doorway heat loss issue, to some extent, with EPS foam between slab & outside concrete wall and a 2" x 12" PT board on top to bridge the gap.
The 2x12 at the outside edge sits on 1.5" angle Iron that is attached to the inside of the 8" concrete wall with 3/8" RedHead anchor bolts, the inside edge of the 2x12 sits on top of part of the concrete slab that was allowed to run under it for a few inches, very secure.
I will need to dress it up on top with something that won't conduct too much heat out.
