Old 12-06-10, 12:14 PM   #11
hamsterpower
Originally Posted by Higgy View Post
if you wanted to do one room at a time, one year at a time. You could have your whole house spray foamed in less then 10 years.
This is what I'm doing. The coldest room in the house is now the warmest.
Just pull down the drywall, get rid of the bat insulation, spray foam, and throw your drywall back up. Tape, seal and paint.
Don't forget: trim, caulk, clean up, and all the little details that "might as well fix now". My project also included, framing, the walls thicker, plumbing (moved a heater for the thicker walls), electrical (moved switches/outlets for thicker walls), and a closet shelf system (to make my wife happy).
hamsterpower is offline   Reply With Quote
