Old 02-19-10, 02:10 PM   #1
bennelson
Home-Wrecker
Default Ben's Solar Hoop House
Hey Everyone!
A friend of mine has a conduit bender specifically designed to bend standard 10' long conduit into a 6' half circle. I stopped over, and he showed me how to use it. (Thanks Rob!)
I bent up 9 conduits to use as supports for basic little greenhouses.
I simply pounded a stake into the ground to make a hole, then put the conduit's ends into the holes, the cover with construction plastic.
One hoop house is done so far. I propped up the supports for the other, just to show how it will look. I hope to do two more hoop houses this weekend.
Photos below!
-Ben
MobileMe Gallery
