You could always just make a few notes and film yourself and upload it to youtube.
I thought up a couple more questions:
How do you handle electrical boxes?
The netting I've seen on BIS is an 8ft wide sheet. The stuff we have at the home improvement store here is only 5ft wide. Do you hang it vertically or horizontally? I'd imagine it would have to be vertical so you can seal the ends with staples in the studs.
I'm hoping to insulate sometime this week btw.
