Old 04-13-14, 06:22 PM   #21
Elcam84
The only thing I have found to clean the foam before it cures is brake cleaner. You can clean the regular greatstuff cans and tubes with it and also spray it into the nipple of the can and you can reuse the can at a later date. Brake cleaner is basically methanol in a spray can.
