Old 03-11-22, 06:27 AM   #4
Brandon727
Originally Posted by JRMichler View Post
I'm not in the south either, but last summer we had several days in a row with temperatures over 90 deg F. The AC finally started on the fourth day because it took that long for the house to heat up. We do not have any radiant barriers, but do have 32 inches of insulation in the attic.
A radiant barrier is better than nothing, and plenty of insulation is much better than any radiant barrier.
Why not both? Radiant barrier will be about $100, then I'm gonna add blow in insulation, not 32" but ~R40 which is adding 12" to the current insulation of about 6-8", should get me close to R60
Brandon727 is offline   Reply With Quote
The Following User Says Thank You to Brandon727 For This Useful Post:
JRMichler (03-11-22)
