Originally Posted by MEMPHIS91
In order to properly insulate the containers you ... loose most your inside space...
"most" implies more than half of the inside space.
Do you really think that is true?
I have seen quite a few European projects, and they are all insulated on the interior with spray foam, and then the wall covering of your choice.
Any conversion that looks like a container on the outside is insulated on the inside. Just look at the examples in the first post of this thread.
