I should have given more details than what I did. I have helped build one before. So here is what we ran into. First they must be sat on blocks or something else to keep them off the ground because the floors are wood. Crazy thick wood that you have to awesome die in order to get your 4" PVC plumbing into. Next big issue is the walls are not flat, they are beveled and are a pain to cut windows into as well as try to seal from water. Most containers are 7 feet 8-10 inches wide. With 6" stud walls for the needed insulation from the massive metal thermal bridge you loose another foot. Add dry wall and you loose anther 1" or more. You loose 8" on the ceiling. So already you have a tight tight tiny long box to live in. That is barely insulated to a mid climate standard.
Let's say you want to put serveral of them together to make it bigger, that's fine as long as you are making it wider but now you better weld those seems good or its going to leak. You also must keep the top painted because it rust quickly.
My body used 5 to make his place, and every day he wishes he would have jaw built a normal sick house. He spent just as much on the contained home as he would have a sick home that would have been better insulated. They MUST be shaded in the summer or they will run your cooling bull crazy heigh.
I guess if it's just one or two people and you can live in a one container tiny home, then it might really be best, but the time and effort it takes to cut and line up and reweld massive pieces of steel in my experience is a huge waster of torch gas, money and time.
