Hot water collector
This has probably been talked about before but can you use the swimming pool solar heating kits to heat water for use in the house.
I'm talking about the flexible mat that is used as the collector in those kits.
Can you put that mat inside a box to use as the collector plate for solar hot water heating?
Can it withstand the temperature inside the box?
