Water temps in radiator..
Sorry about the mix up.. I thought I was responding to Sunspot when I asked about a leak at the collector with a drainback system.
I can not afford to fly to Finland but if I could I would come out there and try my best to get you to switch your system over to a drainback system.
Much less complicating.. no pressure.. no glycol... no nothing and they work flawlessly.
Pat from Warwick, RI
Please Note:
Comments and/or suggestions I make here at the forums on 'your' projects as well as my own have all been carefully and scientifically calculated by 'the seat of my pants' To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
