Great idea, I will try to research more on that, thanks a lot.
In the mean time I ve got a good offer for a heat exchanger that looks undersized for its specs , would this fit my unit ? I mean the price its very affordable, so please tell me if this would work because I ve very enthusiast about having it sorted that cheaply.
http://shop.wiltec.info/product_info...er-125-kW.html
Model B3-23A-30
Number of plates 30
Length / Width / Height
(without connections, in mm) 315 / 73 / 74,2
max. flow 4 m³ / h
Connecting height 20 mm
Capacity 0,040 l per Plate = 1,20 Liter
Effective exchange surface 0,023 m² per Plate = ca. 0,69 m²
Temperature range -195°C up to +225 °C
Operating pressure 20 bar
Power max. 125 kW
Plate material stainless steel AISI 304
Connecting piece material stainless steel AISI 304
Circulation F1 -> F3 / F4 -> F2
Connectors F1 & F3 12,7mm (1/2") (according to ISO-G)
F2 & F4 25,4mm (1") (according to ISO-G)
Soldering material 99,9% copper
Weight in kg 2,5
