I kicked it up to 40 psi last night before calling it a night. I was pulling 3.3 amps with the discharge at 275 psi. I'm thinking once I remove the coil going around the pump, the try even higher suction pressure. This build might need a larger compressor, or the cap tube more fine tuned.
