Old 02-09-15, 12:18 PM   #5
Originally Posted by Mikesolar View Post
....there is no real need to get a higher conductivity out of a concrete slab as the dT over the loop is usually appropriate for length of tubing and size of room. Having a higher heat draw out of the tube would only mean, IMO, that a typical 250' loop length would be dropped to (for example) 200'...
I have seen this kind of reasoning before, here on EcoRenovator.
It is correct if your objective is to build the minimum heat-transfer structure.
However, if it is your intent to build a system with maximum efficiency, then another kind of reasoning is called for...
