Thinking about the btu rating compared to a resistance heat strip dryer. I think 5kw is the common rating, so about 20kbtu. For cost I would wager the compressor system is more similar to a window unit vs a mini split. Some gains could probably be made with a modern style compressor. Don't forget a good amount of power is also used turning the drum full of clothes.
